The input resistance of the preamp is 50k ohms because it has two 100k resistors biasing it.i am a bit confuse about this. if every RC network have same cutoff frequency, why can not use same value of RC since the calculation will get back the same cutoff frequency?
The input resistance of the tone controls circuit is 100k ohms so its input coupling capacitir has a smaller value than the preamp. But its resistor values can easily be reduced to use the same capacitor value.
Maybe you cannot find a 50k ohms volume control then its input capacitor value must be re-calculated.
The input resistance of the LM386 amp is typically 50k ohms so it can use the same value coupling capacitor as the input of the preamp.
But what about the capacitor that feeds the low resistance of the earphones? Its value will be much higher than the others.
The 10uf capacitor filters low frequencies and the 0.1uf capacitor filters high frequencies. They are connected in parallel so that all frequencies are filtered from the supply.For the 3-way tone controls, all power supply pin have to decoupled with 10uF and 0.1uF capacitor, i know that the +ve pin should connect to 0.1uF capacitor, but how about the 10uF, where should i connect it?
The pot adjusts how much gain (boost) or loss (cut) there is in the bandwidth of the filter.I try this 3-way tone controls in stimulator, but i am not sure how it work, is that each band of pontentiometer is use to control the amplitude(peak-to-peak) of particular frequency?
