Right. The PCBScope I ordered yesterday arrived lunch time today.
It's a bit rubbish but here's a trace off a 5v 20kHz square wave. I used my scope lead and a few wires so it wouldn't ever be that clean.
Then the Gould's internal cal 1v/1kHz square wave (and the software measured exactly 1kHz)
I'm not quite sure why the horizontal time base shows the wave as nearly identical. Changing the s/div seems to have no effect on the wave but I know it's around the 20kHz as it was measured and calculated on the Gould when it worked. I haven't bothered to learn the software at the moment but it is very buggy and keeps crashing on both PCs I've tried to use it on. Edit: Apparently it does eventually show the wave widening once you get down into the uS region.
Here's the output on the emitter of the TR183. I had to use the x10 on the probe to attenuate the signal for the PCBScope. There is some movement but it can't be more than a few volts of oscillation.
The 'osicllation' was similar when I had the TR183 totally disconnected.
For the moment I have only replaced the electrolytic caps on the oscillator board. So I may just put the originals back on if it eventually comes good.
