Kermit,
I suggest that you use some Threadlocker Blue, or at least a dab of paint or nail polish on each of the screws/nuts; otherwise you will likely find that your projects' screws/nuts will soon vibrate loose.
You might also consider using rubber grommets to make a flexible mount.
If the fan box is vibrated significantly by the compressor, it may put very high loads on the fan's bearings, which will shorten its' lifespan.
