*Only* 4-5 amps?At the higher voltage, I only needs 4-5amps.
That is ok!
A car battery is more like 11V - 14.4V, not 12V. In fact 12V would be a very flat battery.I need a circuit that will take 12vdc(from a car battery) and make it into a higher voltage. I want to be able to adjust the volt any were from 1 to 60v. The power of that will go into a pwm.
This works out to 120W.Well, It will not be that much. It would be nice to have it go up that high. But I went it to do at least 60v and 2 amps.
by Robert Keim
