What is the best technique to design a 9V, 3Amps power supply that limits current at 2.7 Amp. I would like to stick to linear technology but design a circuit that is also efficient with best accuracy I can get. Any hints?
One thing you'll want to do is better define your specifications. Source power? Allowed ripple size (as a function of current load)? Is normal operation at constant voltage (your 9V) or constant current (2.7A)? Do you want to vary that specification? What do you want the supply to do when the load is excessive, such as a short (blow a fuse, sound an alarm, light an LED, shut down)? The experts can't help you much unless they know what you want.What is the best technique...
