I have a project that I would like to use two small push button style switches, to control the direction of a dc motor.
The details are a 12 volt DC battery (lawn mower battery), power window motor, not sure on any specs for this motor.
I do NOT (and can't) use one switch (DPDT). Is there a way to wire this so that two switches can be used, one will make the motor spin forward and the other will make the motor spin in reverse. I don't know if a relay needs to be used, as to protect the circuit from both switches being pressed at the same time by accident. They need to be momentary switches, so when the push button is pressed the motor spins then stops after being released.
Can somebody provide a list of items needed (switch types SPST, SPDT, RELAYS, ETC.) and a diagram to wire them. THANK YOU!
