Thanks for your suggestion,
I will have to purchase another set in the morning.
Are there alternatives to the 7447 that do not include the 7448?
The other question I have for you is:
How do I add a pause button in a timer circuit?
Sala
The NTE960 regulator datasheet is missing a lot of information that a standard 7805 regulator IC would have in it.
The NTE960 requires an 0.33uF cap from VIN to ground, and an 0.1uF cap from VOUT to GND. Without these caps, the regulator can oscillate at high frequencies (particularly in a breadboard) and the output voltage will not be correct.
The .33uF and 0.1uF caps must be located as close to the regulator as possible.
You could probably get by with a 1uF instead of an 0.33uF.
What happens if you leave the caps off, is that the inductance of the wiring coupled with parasitic capacitance along the way can create a resonant circuit; one that resonates at a very high frequency. Placing caps immediately adjacent to the regulators' inputs and outputs swamps that effect.
