7 segment display total confusion
RodneyB
Joined Apr 28, 2012
697
I am trying to make a novilty number to be displayed on our post box. I have a dual seven segment display KingbrightDA56-11EWA. Common Anode right hand decimal.
As I wanted to be able to display severalnumbers I am trying to drive the 7 segmentdisplay with a SN74LS47N Which is A BCD 7 Segment display driver Yje Datasheet shows a maximum 15 Volts. Is that the maximum supply voltage for the IC.
I Have Pins 4 & 5 B1/RB0, RB1 ( both on data sheet have lines shownabove them and I have no idea what that means or how to show it here. ) connected to the positive.
Pin 3 LT (Again with a line able it ) can be switched to goto the positive
Pins 1,2 6,7 B,C,D,A Can be switched on to the positive or off .
The pins to the 7 segment display are connected through a 150R resistor. The common on the Display is connected to the +ve.
I have connected a 5 Volt supply andnothing happens.
I have removed the IC and Taken a jumper from the Negative through each resistor and each segment lights up. But Icant get it to work from the IC and nervous to increase the voltage from 5 volts,I cant seemto findthe correct supply voltage.
Assistance willbe appreciated.
Thanks
Rodney
30,807
Do not increase the voltage above 5V.
Post a circuit diagram.
Post a photograph of your wiring.
Did you connect pin 8 to GND and pin 16 to +5V?
Temporarily connect pin 3 (Lamp Test) to GND and you should see all segments light up to display 8.
You cannot simply connect switches from +5V to A, B, C, D inputs because TTL inputs will float high.
You can either use 100 - 220Ω pull-down resistors or a better solution is to put the switch to GND and use 1k - 4.7kΩ pull-up resistors.
How many digits do you need and what number do you want to display?
30,807
The LED shows CC on pin 6. I presume you meant CA as in common-anode.
Don't wire the switched to +5V. Wire the switches to GND (pin 8 of 74LS47)
and close the LT switch at pin 3 (to GND) and tell me what you get.
RodneyB
Joined Apr 28, 2012
697
I connected all the switches to the negative .
Pins 4 & 5 connected To the Positive
Pin 3 connected to the negative and switched on and all the segments come on showing the figure 8.
Pin 3 switch off all segments off
Then its strange what happens next
according to the data sheet
B= L
C=L
D=H
A=H
shouldgive the digit 3
Howeverit displays a 6
I went through allthe combinations shown on the data sheet and nothing corresponds.
I connected pins 4 & 5 to the negative and nothing came on. Conected them backtothe positive Lamptest works and Still get 6
Thanks
Rod
RodneyB
Joined Apr 28, 2012
697
Many thanks for all the help I had a join between 2 tracks and I was making a mistake reading the data sheet forthe numbers. I just want one last piece of advice! I want to add some spark to this so want to add some routine to the display using a PIC12F675. If the Pins on the pic are low, will the 7 segment displaystill light up with out damaging the PIC. I want to Run the routine on the pic, lighting segments on the display and eventually counting down tothe desirednumber.
