Looking for someone to start me in the right direction here.
What I'm trying to do is design a simple 7 segment led display that is driving off of a 7 voltage differentials. I'll explain.... I am trying to make a gear indicator display for a motorcycle. There is a gear indicator on the motorcycle that for each gear position utilizes a different resistor value inline back to the ECU.
I saw this design here. http://www.bluegauges.com/gearindicatorplans.htm
but I would like to replace the LED's with a 7 segment that reads out the gear number.
Does someone see a simple way to convert the schematic in the link above to do what I want.
I'm working on it, but I'm sure someone else here could spot a better way than what I'll probably come up with.
Thanks for any help
Thanks for any help
