HW 8 channel SERVO/MOTOR output on 18F4431 (Oshonsoft)
camerart
Joined Feb 25, 2013
3,730
I'm trying to control 5xPWM outputs on an 18F4431 PIC, in Oshonsoft.
I have examples saved, even ASM CODE written by 'E', but they aren't suitable, as most use the CCP modules on the PIC, and there are only 2x.
There is a section in the PIC D/S that shows 8 PWM channels, but they appear to be in pairs, which is confusing.
Can anyone give me a few clues, please?
Camerart.
John P
Joined Oct 14, 2008
2,026
As in the best tradition of this forum, you're asking for help and explaining nothing. Please say what frequency these PWM outputs need to have, and how much resolution you need to provide.
camerart
Joined Feb 25, 2013
3,730
Hi J,
Good, I like to keep up the best traditions :)
They are for radio controlled SERVO/MOTOR control, so 20kHz I think.
C
camerart
Joined Feb 25, 2013
3,730
The IC appears to provide 8 single channel PWM, or 4 half-bridge outputs, or 2 full-H bridge outputs.
Hi M,
I read PWM 0 to7.
If so, then I've got to figure out how to set them.
I'm sure I have an example, and I'm still looking for it.
C
MaxHeadRoom
Joined Jul 18, 2013
28,688
Hi M,
I read PWM 0 to7.
C
The total gives you 8 single PWM channels, if you need half bridge or full bridge, then you are going to exceed those available if using anything but single for a qty of 5.
upand_at_them
Joined May 15, 2010
940
A user on here (MMcLaren), and ETO (Mike - K8LH), showed how to handle many servos on a micro by scheduling them (software PWM, not using the hardware PWM on the micro).
John P
Joined Oct 14, 2008
2,026
Hi J,
C
Do you mean hobby servos? If so, the control signal is at 50Hz, which is 20msec per cycle. And the PWM output is high for a maximum of 2msec out of that period, though you might choose to add a little more, if your particular servo can accept it.
Depending on how much you're paying for a hobby servo, you might find that 100 increments over the 1msec period of variation (not the first 1msec, which is always high) would be as much resolution as the servo can respond to, so that's a 10usec increment of time that you'd have to control.
camerart
Joined Feb 25, 2013
3,730
Hi U,
I think you are talking about any PIN, with proportional ON/OFF, but I hope to use the dedicated PWM PINS.
C
camerart
Joined Feb 25, 2013
3,730
Hi J,
Yes, plus prop motors, with ESCs.
C.
camerart
Joined Feb 25, 2013
3,730
Hi M,
I don't think I need half or full bridge.
I need 5x at the moment.
C.
BobTPH
Joined Jun 5, 2013
8,967
I am using a PIC PWM at 20Hz?
At what clock speed?
The minimum PWM frequency is:
clock speed / 16 (max prescalar) / 1024.
So for 50 Hz you have:
f / 16 / 1024 = 50
f = 50 * 16 * 1024 = 819200 Hz or an instruction frequency of just over 200,000.
If you need a faster clock, you cannot PWM at 50 Hz
Bob
camerart
Joined Feb 25, 2013
3,730
f / 16 / 1024 = 50
Bob
Hi B,
The 18F4431 uses an 8mHz crystal x 4 so 32mHz.
I'll have to study what you explain, for me to understand.
C
