I have a shop with a split phase HVAC (no ventilation except for open windows). It has a hand held remote to turn it on, select the function and set the temperature. I'd like to install a programmable thermostat (PT). I have very limited information and am going on the thinking that the display board is the point where I'd install a 5 wire programmable thermostat.
Two questions:
1) Based on the diagram below, correct me if you think I'm wrong, CN 2 is where I'd connect the PT. It would be the 5 wire variety likely.
2) What would you consider to be a decent PT? Doesn't need to be a NEST Self Learning type. Just one that is easily programmable and with humidity sensing abilities. Humidity is an important factor in my wood shop.
![HVAC Schematic.png HVAC Schematic.png](https://forum.allaboutcircuits.com/data/attachments/311/311751-1003a40912e189912089ee74bc8b1116.jpg)
As for name brand of my split HVAC unit - I'd have to go look and see if I can find a label. It's an off name brand. Works decent.
Two questions:
