Hello All About Circuits forum,
Using an Arduino to control a dozen 4017 - 555 circuits to sequence
320 LEDs. The problem is the 4017 turns on LED 1 then turns it off
and then turns on LED 2. The project wants to turn on LED 1 and
leave it on and then turn on LED 2 and leave LED 2 on, then
turn on LED 3 etc.
Maybe the 4017 won't do this but does any one know if it will
and if so how?
Thanks.
Allen in Dallas
Shift register (74xx595 or 4094).Hello All About Circuits forum,
turn on LED 3 etc.
and if so how?
Thanks.
Allen in Dallas
320 outputs, post #1.I'm assuming that you want 10 digit output here.
That's not a bad price if you need 50 pieces. $0.31 each. <<< Good buy.
That's equivalent to the OR operations built with diodes. The diode approach is cheaper and more affordable, however.4017 "stacker".developed for Oxbow-Rene.
Decade counter 4017!!! | Digital Design | 25 | ||
M | 4017 Decade counter modifying clock | Digital Design | 12 | |
C | 4017 counter signal to toggle between two PWM signals | Digital Design | 79 | |
4017 decade counter clock input | General Electronics Chat | 3 | ||
L | Verifying 4017 Decade Counter | Digital Design | 9 |
by Jeff Child
