ok .The latest circuit is almost the same as figure 12 in the datasheet for the TDA2030A.
It does not use and does not need darlington output transistors because its output power is not high.
It is an ordinary stereo amplifier that is not bridged. Since its supply voltage is only 36V then its output power per channel is only 28W at clipping into 4 ohm speakers.
If the two amplifiers are properly bridged then the output power will be about 100W at clipping into 4 ohms.
but I want 100w+100w Streeo setup or 200w bridge so what is transistors ?
what is circuit revision (semiconductors - resistors - Capacitors and ....)
