#define _XTAL_FREQ 8000000
#include <xc.h>
// PIC18F45K80 Configuration Bit Settings
// 'C' source line config statements
// CONFIG1L
#pragma config RETEN = OFF // VREG Sleep Enable bit (Ultra low-power regulator is Disabled (Controlled by REGSLP bit))
#pragma config INTOSCSEL = HIGH // LF-INTOSC Low-power Enable bit (LF-INTOSC in High-power mode during Sleep)
#pragma config SOSCSEL = HIGH // SOSC Power Selection and mode Configuration bits (High Power SOSC circuit selected)
#pragma config XINST = OFF // Extended Instruction Set (Enabled)
// CONFIG1H
#pragma config FOSC = INTIO2 // Oscillator (Internal RC oscillator)
#pragma config PLLCFG = OFF // PLL x4 Enable bit (Disabled)
#pragma config FCMEN = OFF // Fail-Safe Clock Monitor (Disabled)
#pragma config IESO = OFF // Internal External Oscillator Switch Over Mode (Disabled)
// CONFIG2L
#pragma config PWRTEN = OFF // Power Up Timer (Disabled)
#pragma config BOREN = SBORDIS // Brown Out Detect (Enabled in hardware, SBOREN disabled)
#pragma config BORV = 3 // Brown-out Reset Voltage bits (1.8V)
#pragma config BORPWR = ZPBORMV // BORMV Power level (ZPBORMV instead of BORMV is selected)
// CONFIG2H
#pragma config WDTEN = OFF // Watchdog Timer (WDT disabled in hardware; SWDTEN bit disabled)
#pragma config WDTPS = 1048576 // Watchdog Postscaler (1:1048576)
// CONFIG3H
#pragma config CANMX = PORTB // ECAN Mux bit (ECAN TX and RX pins are located on RB2 and RB3, respectively)
#pragma config MSSPMSK = MSK7 // MSSP address masking (7 Bit address masking mode)
#pragma config MCLRE = ON // Master Clear Enable (MCLR Enabled, RE3 Disabled)
// CONFIG4L
#pragma config STVREN = ON // Stack Overflow Reset (Enabled)
#pragma config BBSIZ = BB2K // Boot Block Size (2K word Boot Block size)
// CONFIG5L
#pragma config CP0 = OFF // Code Protect 00800-01FFF (Disabled)
#pragma config CP1 = OFF // Code Protect 02000-03FFF (Disabled)
#pragma config CP2 = OFF // Code Protect 04000-05FFF (Disabled)
#pragma config CP3 = OFF // Code Protect 06000-07FFF (Disabled)
// CONFIG5H
#pragma config CPB = OFF // Code Protect Boot (Disabled)
#pragma config CPD = OFF // Data EE Read Protect (Disabled)
// CONFIG6L
#pragma config WRT0 = OFF // Table Write Protect 00800-01FFF (Disabled)
#pragma config WRT1 = OFF // Table Write Protect 02000-03FFF (Disabled)
#pragma config WRT2 = OFF // Table Write Protect 04000-05FFF (Disabled)
#pragma config WRT3 = OFF // Table Write Protect 06000-07FFF (Disabled)
// CONFIG6H
#pragma config WRTC = OFF // Config. Write Protect (Disabled)
#pragma config WRTB = OFF // Table Write Protect Boot (Disabled)
#pragma config WRTD = OFF // Data EE Write Protect (Disabled)
// CONFIG7L
#pragma config EBTR0 = OFF // Table Read Protect 00800-01FFF (Disabled)
#pragma config EBTR1 = OFF // Table Read Protect 02000-03FFF (Disabled)
#pragma config EBTR2 = OFF // Table Read Protect 04000-05FFF (Disabled)
#pragma config EBTR3 = OFF // Table Read Protect 06000-07FFF (Disabled)
// CONFIG7H
#pragma config EBTRB = OFF // Table Read Protect Boot (Disabled)
#define S1 LATBbits.LATB0
#define S2 LATBbits.LATB1
#define S3 LATBbits.LATB2
#define S4 LATBbits.LATB3
// Initialize the device
void Port_pins_Initialized (void)
LATA = LATB = LATC = LATD = LATE = 0; // set all to 0
TRISA = 0b0000000;// all are output, Unused
TRISB = 0b0000000;// control signal S1, S2, S3, S4 (0-3))
TRISC = 0b0000000;// All are output, Unused
TRISD = 0b0000000;// segment board connected
TRISE = 0b0000000;// All are output, Unused
ANCON0 = 0; // digital port
ANCON1 = 0; // digital port
CM1CON = 0; // Comparator off
CM2CON = 0; // Comparator off
ADCON0 = 0; // A/D conversion Disabled
void main(void) // main program start
Port_pins_Initialized (); //// Initialize the device
S1 = 1; S2 = 1; S3 = 1; S4 = 1; // select all
while(1) //Run forever
S1 = 1; S2=S3=S4 =0; // select only 1st segment
LATD = 0x3F; // Display 0
__delay_ms(1000); // Wait 1 seconds
LATD = 0x06; // Display 1
LATD = 0x5B; // Display 2
LATD = 0x4F; // Display 3
__delay_ms(1000);// Wait 1 seconds
LATD = 0x66; // Display 4
LATD = 0x6D; // Display 5
return ;
int counter=-1;
int temp;
byte digits[]={0,0,0,0};
counter++
temp=counter;
for (int i=0; i<4; i ++) {
digit[i] = temp % 10;
temp = temp /10;
That method is as good as any but your digits are backwards. This will fix it.Your content value can be treated as either binary or decimal. If you think of it as decimal, a few lines of code can convert it into the equivalent digits. Then, display those digits. May not be efficient, but should work for your test.
Code:int counter=-1; int temp; byte digits[]={0,0,0,0}; // . . . counter++ temp=counter; for (int i=0; i<4; i ++) { digit[i] = temp % 10; temp = temp /10; }
temp=counter;
i = 4;
do{
i--;
digits[i] = temp % 10;
temp = temp /10;
}while(i);
M | A 6 Digit Frequency Counter | Digital Design | 99 | |
M | 3-Digit Counter | Digital Design | 46 | |
N | Mod 13 Counter (2-Digit Display) - Multisim | Homework Help | 1 | |
2-Digit Counter Circcuit | Digital Design | 18 | ||
M | Designing a stopwatch( 3 digit counter) | Homework Help | 32 |
by Jeff Child
