Does having low ESR, doesn't this change the charge time or discharge time?
Well yes - but its rather irrelevant when you have a 100R resistor in series.But that's good to have a low ESR? Right
Since we are talking a internal resistance inside the capacitor, what do you think?Equivalent series resistance - Wikipedia, the free ...
en.wikipedia.org/wiki/Equivalent_series_resistanceWikipedia
Jump to Capacitors - Capacitors[edit]. In a non-electrolytic capacitor and electrolytic capacitors with solid electrolyte the metallic resistance of the leads ...Overview - Component models - See also - References
You may have to wait for the book to come out, we must be approaching the deadline with the amount of content so far.Ok from another thread I have been asked to ask you this Dexter.
ARE these drawings from part of a airplane or airplane system or not? .
In high current pulse applications like SMPSU, ESR can be dead critical - but in a CR timing network where R is in hundreds or thousands, it would have to be a pretty bad capacitor to even exceed the standard tolerance of a resistor.So having high or low ESR, changes the time constant formula RC = T, having low or high ESR changes R TOTAL
Why only in high current pulse applications? so the voltage and current have to be really HIGH for ESR to be addedIn high current pulse applications like SMPSU, ESR can be dead critical
What value of resistor in series would be make ESR as issue?Electrolytics in parallel also give a lower net ESR than a single cap - but that's hardly likely to be the issue with a 100R resistor in series with the parallel combination.
so it's all about getting that capacitance value when you add 3 caps together?
by Aaron Carman
by Duane Benson
by Jake Hertz
