Hello
I am new to all this stuff, i mean really new!! page 85 new
I am starting to learn electronics as a hobby and as such have a book "Make: Electronics" that i am currently going through.
I have a question about a circuit that is called Slow speed Oscillation using the 2N6027 PUT, a capacitor and a few resistors.. oh and a LED to flash
But i am getting some unexpected results.. instead of the LED flashing it just turns on as soon as i connect the power and stays on. I am 100% sure that i have the correct wiring etc.. it should flash. i have tried everything in my knowledge to fix this but cannot understand what is happening to make it go wrong :-
The only thing i can think of is that the transistor is wrong but it definatley says 2N6027 on it. are there any checks i can do to see it if it a PUT?
i did notice that if i out a negative charge on the "gate" pin the LED dims and the apposite for positive charge. is this usual behaviour for a PUT?
Anyone can help me out here? the rest of the book depends on adding to this simple circuit
Thanks
- swapped the pins on the PUT in case it is non standard Anode, gate and cathode
- increased and decreased the resistors across the Gate
- Checked, checked and checked again the layout, wires etc.
- changed capacitor, and so on.
Thanks
