It is just a shorter version of 275nm.hello,
What does 265nm mean here??
thanks informative ...UV breaks molecular bonds within microorganismal DNA
The 265 nm part says + or - 3 nm so it is a pretty narrow coverage. How much water can a small LED disinfect?
it's wavelength, check datasheet below:hello,
yes, much appreciated.According to Wikipedia "Particularly at wavelengths around 250 nm–260 nm,[7] UV breaks molecular bonds within microorganismal DNA, producing thymine dimers that can kill or disable the organisms."
Based on that, I would guess (I'm no expert in the field) that the shorter wavelength (265nm) would be more effective.
hi John, you mean 254nm is better at absorb soluble compounds, but 275nm not?It is just a shorter version of 275nm.
As for the TS, I suspect the science of water purification will answer your question. In the days of using low-pressure mercury lamps, we used 254 nm.
@Alec_t All things being equal, I agree. However, there are likely matrix effects. For example, if the contaminated water contains soluble compounds that absorb at 254 nm (the old standard) but not so much at 275 nm, the latter might be more effective at sterilization. However, those wavelenths are so close, I suspect differential absorption is not a big factor. Then, you have to consider the possible effect of photosensitizers in the water (also probably unlikely) that might change the optimal wavelength.
Since public safety is at issue, it seems to me to be a situation that has an empirical answer, rather than simply a theoretical one.
John
this is hard to say, distance decide it's power effect, so does the mercury lamp.The 265 nm part says + or - 3 nm so it is a pretty narrow coverage. How much water can a small LED disinfect?
What kind of power did the mercury vapor lamps put out? Equal to how many LEDs?
Generally speaking, the shorter the wavelength of UVC, the more is absorbed. "Cut-off" is used to describe that effect for various solvents used in spectroscopy. I have not studied environmental water and can't say what sort of cut-off it may have in the UV; however, it should not take very much dissolved iron (to mention just one common solute) to reduce the UV transparency .hi John, you mean 254nm is better at absorb soluble compounds, but 275nm not?
and the function also decided by photosensitizers?
before we also use 254nm mercury lamp.
Do you have a way of testing the effectiveness of the LEDs?Generally speaking, the shorter the wavelength of UVC, the more is absorbed. "Cut-off" is used to describe that effect for various solvents used in spectroscopy. I have not studied environmental water and can't say what sort of cut-off it may have in the UV; however, it should not take very much dissolved iron (to mention just one common solute) to reduce the UV transparency .
A "photosensitizer" can be viewed as a photo-activated catalyst for photochemical reactions. They can help facilitate reactions that would not normally occur.
Microbiocidal activity of UV is not a simple subject, and there are statements in the literature to the effect that UV wavelengths longer than 254 nm are more effective than 254 nm is itself. Remember, 254 nm was used originally mainly because there was a convenient source for light of that wavelength, and it was effective. It is not necessarily optimal.
As I said, your question touches on a matter of public health, and I would advise doing a thorough search of scholarly studies on the question rather than go by opinions. There may also be governmental regulations with which you will need to comply.
John
http://www.steripen.com/Aqua
The question is about effectiveness before it is about cost. Does it work? How much power is required?I actually bought some 265nm, 275nm,310nm, 365nm led from Shenzhen Shining Future company and it's still working pretty nice.
No, sometimes it is just marketing, "this water has been treated with UV"The question is about effectiveness before it is about cost. Does it work? How much power is required?
If you work in a water purification business I would assume you have a way of testing these things.
So the company doesn't really care if it is effective?No, sometimes it is just marketing, "this water has been treated with UV"
by Dale Wilson
