Hi, we are designing a 48V high side MOSFET switch and we realised that the our mosfet gets too hot. Our solution is to connect additional mosfets in parallel to distribute the load/heat. But I'd like to ask your how to properly connect PMOS in parallel. I read somewhere that the gates should have separate resistors (i dont really understand why)
but im not sure how to do this with our current circuit:
im thinking to have separate zener diodes, 10k and 22K for each additional pmos, then connect them all at the drain of the NMOS.
is this the right way to do this or is there a better way? or can i get away with connecting the gates together and have them share the same zener and resistors?
