Hi!
I want to know if anyone has tried these circuits and tell me if he has met any pros and cons which I should consider.
3 to 5V shifter:
Pros are its simple, it has a minimum amount of components, SMD components can be used instead of normal ones, it can be used for fast switching up to 10MHz including on an SPI interface, it can be used in industrial conditions without any interference from the surrounding noise.
WiFI module:
Pros are its simple, it uses ESP8266 which will just be mounted on 2 pin headers making it easy to replace, it works well in industrial conditions, its possible to 256*256 modules with internal IP addresses
3 to 5V shifter:
WiFI module:
