Cc/cv converter as current limiter
bigjoncoop
Joined Feb 1, 2019
189
I see many people online talking about using a cc/cv buck or boost converter in order to limit the current when charging 12v Lifepo4 Batteries using a car alternator...
What I don't understand is normally when using such a device, the voltage input must be slightly higher or lower then the target output voltage.
But a 12v lifep04 battery is fully charged at 13.8v the same as a car lead acid battery. The car alternator is also only outputing 13.8v also... So how would you use a buck or boost converter to fully charge the battery?
Now granted it's better off to normally not completely fully charge lifep04 batteries since it will greatly increase their lifespan. But as far as I remember a buck or boost converter needs a voltage higher or lower usually by a couple of volts correct? If so that's way to much of a difference...
Now I do know that obviously the best solution for this is to just use a dedicated DC to DC charger that is designed for this application. But they are normally fairly expensive.
But I see tons of people online talking about doing it this way. And they're normally just using those large red 1500 boost converters. (photo below)
18,600
In an automotive alternator charging system the voltage is regulated to control the charging current. It does not seem reasonable to use a similar system for any type of Lithium technology battery systems.
Ya’akov
Joined Jan 27, 2019
9,170
A "12V" LiFePO4 battery is actually a 12.8V battery (four 3.2V cells in series). This means the optimal charge voltage is a little higher than the 13.8V the car's system is designed to provide the PbSO4 battery that is normally installed.
While charging with a lead acid charging is usually OK, if it is a high quality charger and properly maintains voltage and current, the best charger for a LiFePO4 battery is going to be just a bit hotter than the car's system.
The biggest danger is a bad alternator with poor voltage regulation. The battery's BMS could respond to a momentary over voltage by disconnecting the battery, possibly not in an easily resettable way. Using a buck converter is one way to deal with this, but if you are going to put a DC to DC converter in place, why not use a buck-boost so you can usually get the more ideal 14-14.2V charge?
This is an alternative to a better 13.8V voltage regulator which will also work, and might be cheaper, but will slightly undercharge the battery.
Danko
Joined Nov 22, 2017
1,835
Exactly what you need, especially for lithium battery:
https://www.aliexpress.us/item/3256...!sea!US!4576908365&curPageLogUid=e8HgatAdl0cr
Bullet Points:
1,MPPT+PWM Coexist Function: The solar charge controller will automatically adapt to the adjustment charging mode (MPPT/PWM), and automatically adjust the charging according to the type of battery.
2,Small Tip: For example, lithium batteries need to use the MPPT charging method, and those that can charge 12V acid batteries use the PWM charging method.
3,LCD Display: The solar charge controller features the large-screen LCD display, charge and discharge current display, cumulative power generation and discharge power query, temperature display, light control + delay control; adjustable charge and discharge parameters, with functions such as power-off memory.
4,Dual Ports: The solar charge controller features the dual USB ports, the maximum current of it is 2.5A, and it supports for Apple's mobile phone charging.
5,Multiple Functions: The solar charge controller features is equipped with all necessary protection devices, the control parameters of the system are adjustable, easy to set up and operate. Built-in short circuit protection, open circuit protection, reverse connection protection, and overload protection. Reverse current protection, low heat generation, self-recovery function,.
Description:
The solar charge controller is suitable for solar green light, solar light box, advertisement board, solar insecticidal lamp, house solar power generation system, marine solar power generation system and outdoor living solar power generation system.
Features:
Real-time display of temperature, charging current and discharge current.
Current autofocus MPPT tracking charging, high charging efficiency, charging process does not stop detection, two-way focus tracking.
Charge 12V /24V lithium battery, super wide charge and discharge adjustable.
The minute is adjustable when the output is turned off, which is more convenient (there is no adjustment when the market is only available).
Built-in overheating, overcurrent, short circuit, open circuit protection, fault elimination, controller automatic recovery.
Two-way MOS tube anti-backflow circuit, high-power charging mode, ultra-low heat.
R5.0 solar charging DC plug, R5.0 DC lamp output DC plug, easy to connect.
Specifications:
Name: LCD Solar Controller
Main color: Black
Main material: ABS
Voltage: DC 12V / 24V
Rated current: 10A,20A , 30A , 50A , 60A ,100A , 150A
Maximum photovoltaic voltage: 50V
Display: LCD screen
Self-consumption: <10MA
Overcharge protection: 14.4V / 28.8V
Overcharge Float charge: 13.7V / 27.4V
Charge recovery voltage: 12.6V / 25.2V
Over discharge protection: 10.7V / 21.4V
Over discharge recovery: 12.6V / 25.2V
Dual USB output: 5V / 2A (charge mobile phone, iPad, etc.)
Working temperature: -35 ℃ -60 ℃
12V fits 18V solar panel, 24V fits 36V solar panel
