I made a simple guitar signal booster for leads. It works, but now I want to add dry / wet mixing. That is, mixing the input with the output. I know proper mixing should be done with an opamp but I don't have space for that. I've also read that sometimes you can get away with mixing two audio signals, each through a resistor.
So naively I added a pot, RV1, as shown in the attached diagram. Stuff added is in the blue rectangle. This eats almost all the signal. Maybe I wired it wrong. Should this in principle work?
Thanks,
hrs
Thanks,
hrs
