What are the pros and cons of:
Thoughts:
Series + Boost benefits:
Parallel + Boost benefits:
- Series Cells vs
- Parallel Cells + a Boost converter?
Thoughts:
- It seems both would provide the same voltage and current.
- Except the parallel boost would have some losses.
- However, if the series pack also has a boost (in order to maintain steady voltage for the load), then both circuits would have converter losses.
- Since the series pack voltage is higher than parallel, the series boost doesn't need to boost voltage as far as the parallel boost. So the series boost would have lower losses than the parallel boost.
- passive balancing
- if cells discharge at different rates such that some cells reach discharge cutoff before other cells, the fully-discharged cells can be removed from the pack without interruption or change in voltage of the boost output.
