I am really struggling with designing a three stage BJT. It has the following requirements:
The input signal shall be a 200 mV peak-to-peak sine wave generated by a standard laboratory signal generator
The midband gain of the amplifier shall be 50 V/V
The output signal of the amplifier shall be in phase with the input signal (not inverted)
The low 3 dB cut-off frequency shall be 20 Hz
The high 3 dB cut-off frequency shall be 18 kHz
The supply voltage shall be ±15 V
The input and output shall be ac coupled to the amplifier
The BJTs used shall be KSP2222A (NPN) and KSP2907A (PNP)
Any help to start designing this will be much appreciated.
