Hi.
I plan to make a pcb that drives peltier and heating pad. Only one of those works at the same time.
Load elements are parallel to capacitors. I have very little space on pcb so it would be nice if I could use only one inductor as it is in screenshot. I know it would be easier just to put two inductors.
Frequency will be 20kHz through low pass filter to act as variable constant current source.
My worry is the current flowing through inactive side diode and capacitor.
Would that be a problem?
Any advice is appreciated
