Hello! I currently have a requirement to make a device that takes two 18650 Li ion batteries to make a 3.3v output. The device requires only about 3mAh of current. However, the system must work when one of the battery is taken out for charging externally. I tried connecting each battery to a MCP1700-3302 regulator, and they seem to work at first.
However, I later found that when one of the battery is at a lower voltage that the other, the battery will stop outputting current, and somehow has the same voltage as the one that is outputting. I need to know the voltage of each battery so I can alert users to take it out and charge.
Can anyone give me some hints at best way to design this? Should I put a diode at the output of the regulators to stop it from affecting each other?
Thank you in advance!
