I have a small project that requires a small turn of about 45 degrees that will return to the original position and it needs to be controlled with a switch. The motor I have was cheap so I'm not bothered if you recommend that I get something else, just needs to be very small. Current motor runs 3.0V 57700RPM 20mA.
I have a basic understanding of electronics so I can understand some things but can pick up things quickly as well. I know that I would probably need a drive board off some kind and to program it with an Arduino. I saw the L298N and a small outline of it so I understand how that one works, but it also seems excessive for my project to have 2 h-bridges as I only need the one motor. The smaller the better so if there is smth smaller that would work better, that would be great.
Again, I dont know loads about this sort of stuff so please be gentle. Very new to this but willing to learn.
Thanks,
Thanks,
