Hello.
At my work, before I came here, someone bought a 7" TFT LCD and it's controller board in the following link:
https://www.ptrobotics.com/lcd-rasp...no-touchscreen-800x480-hdmi-vga-ntsc-pal.html
Some time later, one other guy, while working with it, let the LCD fall on to the floor and it broke. So, he went to a computer shop and the guy in this shop was able to provide a replacement 7" TFT LCD. However, this replacement LCD never worked with the controller and after researching for a while, I acknowledged that each controller board is kind of specific for each LCD model/reference/resolution.
This said, I cannot be sure if this replacement LCD is actually suitable for this controller board or not. Also, after researching a bit more on this subject, I learn that there are firmwares available for different LCDs and I was thinking about trying a few different firmwares and check if anyone would work with this replacement LCD.
So, to contextualize, I'll put here now some links and some info I could find about how to do what I wanted to do.
I found a site where they flash a firmware, I assume, to be able to use different LCD screens with the same controller board.
The link is:
https://www.iot-experiments.com/flash-vs-ty2662-v1-pcb800099/
The datasheet I could find of the controller board is here.
In the above link, long story short, the guy uses an old LCD he salvaged and flashed a firmware onto the controller and he manages to get it working.
He also says he forgot to backup his original firmware (from the control board).
So, first thing I wanted to do was to try to backup my original firmware from this PCB80099 v.9 board.
I'm using this RTD266x EEPROM Flasher software to read / write its memory and I can read it and save it into a .bin file.
What I don't know and need help to understand is that in this software, the write section (to save its EEPROM into a file) there is a field for the Start Address and Length and I don't know what to put in here so I tried to read from Length 256 up to 65536 and it never errored out. Only thing I noticed was that with 65536, there was a section in the middle of the saved file that was only 0xff and then, there was more data until the end.
How can I know what to put in these fields so that I know I have a usable backup of the original firmware?
Mods: Merge the image to this thread.
Another info I can give is that this LCD screen I have is not the original one as that one fall down and broke and someone bought a new one to try to use with this board and its reference is the following:
RFLK-FY7021D01H-3. 5Z-A08 D14011?
The link is:
