Hello. I´m building a heat treating oven. Firebricks and that stuff.
It is small and I have based my calculations in other brand new ones that get around 6.000 watts per cubic feet (I use metric, so this calculations is an effort haha). So, I´ll go for 7.000 watts/cubic feet since mine will be worse isolated than those. Mine is 0,248 cubic feet so 1.700 watts aprox.
I = 1.700/230 = 7,4 amps So the heating element, made of khantal wire has to va a resistance of R = 1.700/7,4^2 = 31 ohms
Until here, everithing is correct. But I see a oven calculator that says that I can go with 1 heating element of that resistance or go with 2 heating elements in parallel, each one of 62 ohms, what makes sense because the total resistance will be 31 ohms, but each one only disipate half of the power, so I don´t think that they get red/yellow hot. I mean, this furnace is supposed to operate between 500-950 ºC (932-1750 ºF) so I´m not sure I could reach these temperatures if I go for 2 elements. Or maybe only 1 element will be too much.
I have found another calculator for the temperature https://jacobs-online.biz/calc2.html and for the 60 feet of 18 WAG wire needed (with onlye one heat element of 31 ohms) it says that the wire will heat at 230 volts to 371 ºC (700 ºF) and doesn't make sense for me.
Any help will be wellcome
Thank you
Best regards
Thank you
Best regards
