Ribbon cable male to board mount female connector.
Tunik
Joined Sep 8, 2021
Hi Folks,
I have a PCB with a 6-pin, 2-row, 2.54 mm pitch female socket (https://www.mouser.ca/ProductDetail/649-89898-303ALF). It was meant to be mated with a right angle mount board connector so that two PCBs would be mated. However, I need to instead use a ribbon cable between the two boards. Can someone help me find the correct male connector? I tried this (https://www.digikey.ca/en/products/detail/amphenol-cs-fci/69830-006LF/1527361) and it fits but the pins are too small (0.55 x 0.36 mm), while I need 0.7 square.
Chuck
