I noticed that 4.7k ohm pull-up resistors are used in this circuit on the read/write memory pins: Saundby's MAG 85(scroll down to yellow text), but in other circuits where the read/write / io/m signals are decoded by the 74138 for example, pull-ups are not used? Is it because in the MAG 85 circuit, the signals are connected directly to the memory device?
Thanks,
Kei
Thanks,
Kei
