AC and DC regenerative electronic load
Irving
Joined Jan 30, 2016
3,898
A regenerative load is typically used for braking of a motor. In its simplest form its a big resistor able to dissipate 100 or 1000's of watts. That works for both DC motors and AC motors. It can also be used for power supply and battery discharge testing, though more usefully a passive electronic load allows dialling in of a constant current or constant power load. Such loads use multiple parallel MOSFETs running in their linear region (ie as a voltage controlled resistance) with significant cooling capability. Simple, sub 300W, units are easily found on eBay, etc. but units capable of 1000W+ are complex and expensive beasts.
For EV's active regenerative electronic loads allow recharging of the battery when slowing down (regen braking) and/or dumping energy into passive loads when the charge rate exceeds the battery capacity. These systems use a bidirectional inverter DC -> AC-> motor -> AC -> DC topology.
morrademedo
Joined Jul 5, 2022
6
An electronic load is fed by an electric outlet. It produces a current to test some other device. But if this device under test is an energy meter, for example, the electronic load would work as a linear amplifier, burning energy in form of heat. Imagine we can return this energy to the outlet instead burn it. This is what I mean by the regenerative electronic load.
Irving
Joined Jan 30, 2016
3,898
Exactly so, as given in my last example above.
garce
Joined Apr 10, 2017
14
this may be what you are talking about:
The active rectifier acts both as as a full wave rectifier when "motoring" and as as inverter when the motor is "generating" to return energy to the mains supply.
Irving
Joined Jan 30, 2016
3,898
That's effectively the EV version, though with a DC feed. Sometimes you see top of the range Variable Frequency Drives (VFD) for machinery (lathes, etc.) do this, though most just use a braking resistor 'cos its cheap.
Also:
garce
Joined Apr 10, 2017
14
Also:
regenerative braking (in case the mains can take the reverse flow with leading power factor without causing an overvoltage) has been very successfully used in operations like large mineral conveyor belts in mines, lots of energy returned to the grid
morrademedo
Joined Jul 5, 2022
6
Imagine that I want to test this system you showed. So I would need to simulate the motor. My regenerative electronic load is the motor simulator, but instead transform the energy sent to the motor, my simulator will return it to the outlet.
LowQCab
Joined Nov 6, 2012
4,078
Accurately simulating a "Real" Motor,
operating in a "real-world" practical-application,
is a seriously daunting task.
Not to mention, the very expensive Software required.
What is the SPECIFIC proposed application for this project ?
It may not be even remotely practical.
morrademedo
Joined Jul 5, 2022
6
in fact, the purpose is to simulate a battery to test a new charger, but instead of burning energy, I would revert it to the outlet.
Ian0
Joined Aug 7, 2020
9,847
I see.
You need a grid-tie inverter such as Victron's MultiPlus, which you can program to take a certain amount of current from the battery and return it to the grid.
I think that the system will need to have a real battery to keep the system stable but you should be able to make the battery look bigger than it actually is by selecting the amount it returns to the grid.
LowQCab
Joined Nov 6, 2012
4,078
"" but instead of burning energy, I would revert it to the outlet. ""
What does this statement mean ???
Burning Energy where ?, in what device ?, for what purpose ?
Where did the "Energy" come from ?, where does it normally go ?, how is it normally wasted ?
morrademedo
Joined Jul 5, 2022
6
I see.
Seems like a good first shot to test the idea. But in the future, I need to replace the battery with an electronic alternative. But it show me a way to start, thanks
Ian0
Joined Aug 7, 2020
9,847
seems a good idea to test the idea, if it works I would change the small battery for a capacitor, and project my own inverter, that will be fast enough to turn possible using that capacitor.
Victron's products are generally far too clever for their own good. You won't fool them into thinking there is a battery when there is a capacitor, but the idea is valid.
If you can find a grid-tie inverter with programmable input current that's not quite so smart you might be on to something.
morrademedo
Joined Jul 5, 2022
6
When I asked this is because I was thinking about making my own inverter to simulate the battery or any other type of load, but my inverter would return the energy to the outlet instead transform it in heat or in movement. But your idea of using a shelf inverter could save me a lot of time.
