I'm copying “Ultra-Wide Input Range Non-Isolated 12V Buck Converter” from LT8316 datasheet into LTspice. But the results seems to be very strange. The voltage on FB is even higher than Vin, which is way above the standard reference voltage(1.22V). I can't find any difference between the datasheet and my LTspice project, all the diodes are confirmed. Can somebody help?
