Hello everyone. I have a question that I already posted elsewhere but I didn't get a clear enough answer for me, and I didn't want to frustrate the kind people over there so I thought I would post it here.
This is not homework and I do not study electrical engineering and I have next to no knowledge of it besides the basics of what current, voltage, and resistance and simple parallel and series circuits is/are.
Below is the question.
The question says:
What is the resultant EMF in the circuit?
Because people asked:
This is a standalone question in a practise booklet for an exam set by a private company, that came with answers but no explanation. The type of questions that the company makes are notoriously badly worded or unconventional, for example some questions ask you to calculate things in a certain way that you would never do in real life. Other times, questions requires you to mind read what they actually mean, in other words, you can understand where they came from if you looked first at the answer, but if you tried to answer the question first, there could be more than one way to do so, leading to different answers. There is no more context I can provide for this question because the questions are standalone (ie, the previous question is for a totally unrelated topic and the next question I already know how to answer).
So, for this question, I know the answer is 18 because the booklet said so. And since it is 18, I also know that the method used to get this was 24-6.
My question is why do it this way when the formula for EMF is e = V + Ir where e = the electromotive force, V is the volts, I is the current, and r is the internal circuit.
What happened to the e = V + Ir formula? Why was this not used at all? People who were discussing this question also said that if the batteries were facing the same way, the EMF would simply be 24 + 6 = 30. This makes sense to me logically because the 2 batteries would be working together to power the device they are part of. But again, the formula is not used. Is the EMF simply a sum of the 2 battery's voltages (I don't think it is)?
The booklet does not provide explanations, instead, people post their solutions online and discuss them in videos or comments in forums. One of the explanations for this is that the batteries's positive terminals are facing the each other so the voltage is working against each other, and the 24V one is going to over power the 6V one. That is all logical even if you don't have any electrical circuit knowledge, but it doesn't explain how you could look at this question asking for EMF and know to simply do 24-6.
I searched for some definitions of EMF online and I found:
"Emf is the voltage developed between two terminals of a battery or source, in the absence of electric current."
and
"EMF is the potential difference measured across a power source without a load connected to it".
To me these bold words mean a circuit that is not using any power or does not have any devices connected to it, for example a circuit with a light bulb that is switched off or simply a closed circuit connected to a battery (this circuit in the diagram is closed, right?). In the diagram, the light bulb would be the 4.5 Ohm resistor. If the light bulb is switched off, then there would be no resistance. The fact that the resistance is stated as 4.5 Ohms means it must be on or having a circuit pass through it.
Thanks in advance.
The question says:
and
Thanks in advance.
