understanding timer logic implementation in EFR32fg14
yef smith
Joined Aug 2, 2020
756
Hello inside the full code shown bellow i am there are timer settings.
There is a smaller function attached bellow.
What is the meaning of top value buffer in timer?
Thanks.
timer setting function:
Code:
void timerSetup(void)
  // Set Timer0 to toggle PA0 at 1 MHz
  CMU_ClockEnable(cmuClock_TIMER0, true);
  uint32_t hfperFreq = CMU_ClockFreqGet(cmuClock_HFPER);
  TIMER_TopBufSet(TIMER0, (hfperFreq / (2 * OUTPUT_FREQ_Hz)));
  TIMER_Init_TypeDef init = TIMER_INIT_DEFAULT;
  TIMER_Init(TIMER0, &init);
  TIMER_InitCC_TypeDef initCh = TIMER_INITCC_DEFAULT;
  initCh.cofoa = timerOutputActionToggle;
  initCh.mode = timerCCModeCompare;
  TIMER_InitCC(TIMER0, 0, &initCh);
  TIMER0->ROUTEPEN |= TIMER_ROUTEPEN_CC0PEN;
  TIMER0->ROUTELOC0 |= SQUARE_WAVE_LOC;
full code:
Code:
 * @file main_gpio_slew_rate.c
 * @brief Demonstrates the slew rate settings for the GPIO. A 1 MHz square wave
 * is generated on a pin. The slew rate setting is changed by pressing PB0. The
 * drive strength setting is changed by pressing PB1. The effects of these
 * settings on the pin's slew rate can be observed by placing a 50uF capacitor
 * on the output pin and observing the change in rise and fall times of the 1
 * MHz square wave.
 * # License
 * <b>Copyright 2020 Silicon Laboratories Inc. www.silabs.com</b>
 * SPDX-License-Identifier: Zlib
 * The licensor of this software is Silicon Laboratories Inc.
 * This software is provided 'as-is', without any express or implied
 * warranty. In no event will the authors be held liable for any damages
 * arising from the use of this software.
 * Permission is granted to anyone to use this software for any purpose,
 * including commercial applications, and to alter it and redistribute it
 * freely, subject to the following restrictions:
 * 1. The origin of this software must not be misrepresented; you must not
 *    claim that you wrote the original software. If you use this software
 *    in a product, an acknowledgment in the product documentation would be
 *    appreciated but is not required.
 * 2. Altered source versions must be plainly marked as such, and must not be
 *    misrepresented as being the original software.
 * 3. This notice may not be removed or altered from any source distribution.
 * # Evaluation Quality
 * This code has been minimally tested to ensure that it builds and is suitable
 * as a demonstration for evaluation purposes only. This code will be maintained
 * at the sole discretion of Silicon Labs.
#include "em_device.h"
#include "em_chip.h"
#include "em_cmu.h"
#include "em_gpio.h"
#include "em_timer.h"
#include "em_emu.h"
#include "bsp.h"
#include "stdio.h"
#if defined(BSP_STK_BRD2204A) || defined(BSP_STK_BRD2102A) /* GG11 or TG11 STK square wave on PD1 */
#define SQUARE_WAVE_PORT gpioPortD
#define SQUARE_WAVE_PIN  1
#define SQUARE_WAVE_LOC TIMER_ROUTELOC0_CC0LOC_LOC2
#else /* All other STKs, square wave on PA0 */
#define SQUARE_WAVE_PORT gpioPortA
#define SQUARE_WAVE_PIN  0
#define SQUARE_WAVE_LOC TIMER_ROUTELOC0_CC0LOC_LOC0
#endif
 * @brief Setup GPIO interrupt for pushbuttons and PA0 output.
static void gpioSetup(void)
  // Enable GPIO clock.
  CMU_ClockEnable(cmuClock_GPIO, true);
  // Configure PB0 as input and enable interrupt.
  GPIO_PinModeSet(BSP_GPIO_PB0_PORT, BSP_GPIO_PB0_PIN, gpioModeInputPull, 1);
  GPIO_ExtIntConfig(BSP_GPIO_PB0_PORT, BSP_GPIO_PB0_PIN, BSP_GPIO_PB0_PIN, false, true, true);
  // Configure PB1 as input and enable interrupt.
  GPIO_PinModeSet(BSP_GPIO_PB1_PORT, BSP_GPIO_PB1_PIN, gpioModeInputPull, 1);
  GPIO_ExtIntConfig(BSP_GPIO_PB1_PORT, BSP_GPIO_PB1_PIN, BSP_GPIO_PB1_PIN, false, true, true);
  NVIC_ClearPendingIRQ(GPIO_EVEN_IRQn);
  NVIC_EnableIRQ(GPIO_EVEN_IRQn);
  NVIC_ClearPendingIRQ(GPIO_ODD_IRQn);
  NVIC_EnableIRQ(GPIO_ODD_IRQn);
  // Set PA0 to push-pull output
  GPIO_PinModeSet(SQUARE_WAVE_PORT, SQUARE_WAVE_PIN, gpioModePushPull, 1);
GPIO_DriveStrength_TypeDef driveStrength = gpioDriveStrengthStrongAlternateStrong;
uint32_t slewRate = 6;
 * @brief Unified GPIO Interrupt handler (pushbuttons).
 *        PB0 Cycles through slew rate settings.
 *        PB1 Cycles through drive strength settings.
void GPIO_Unified_IRQ(void)
  // Get and clear all pending GPIO interrupts.
  uint32_t interruptMask = GPIO_IntGet();
  GPIO_IntClear(interruptMask);
  // Act on interrupts.
  if (interruptMask & (1 << BSP_GPIO_PB0_PIN))
    // BTN0: Slew Rate
    slewRate += 1;
    if (slewRate > 7)
      slewRate = 0;
  if (interruptMask & (1 << BSP_GPIO_PB1_PIN))
    // BTN1: cycle through drive strength settings.
    if (driveStrength == gpioDriveStrengthStrongAlternateStrong)
      driveStrength = gpioDriveStrengthWeakAlternateWeak;
    else
 * @brief GPIO Interrupt handler for even pins.
void GPIO_EVEN_IRQHandler(void)
  GPIO_Unified_IRQ();
 * @brief GPIO Interrupt handler for odd pins.
void GPIO_ODD_IRQHandler(void)
  GPIO_Unified_IRQ();
#define OUTPUT_FREQ_Hz (1000000UL)
 * @brief Timer setup to output a square wave on PA0
 * @brief  Main function
 * This example demonstrates the slew rate settings for the GPIO. A 1 MHz
 * square wave is generated on a pin. The slew rate setting is changed by
 * pressing BTN0. The drive strength setting is changed by pressing BTN1. The
 * effects of these settings on the pin's slew rate can be observed by placing
 * a 50 pF capacitor on the output pin and observing the change in rise and
 * fall times of the 1 MHz square wave.
 * Output pin is PD1 on SLSTK3701 (EFM32GG11 STK) and SLSTK3301 (EFM32TG11 STK)
 * and PA0 on other kits.
 * To test:
 * 1. Place a 50 pF capacitor between the square wave output and GND.
 * 2. Upload and run the example.
 * 3. While observing the rise and fall times of the waveform on PA0/PD1:
 *    a. Press BTN0 to change the slew rate setting
 *    b. Press BTN1 to change the drive strength setting
int main(void)
  /* Chip errata */
  CHIP_Init();
  /* Initialize Push Buttons and PA0 */
  gpioSetup();
  /* Initialize PA0 square-wave output */
  timerSetup();
  /* Infinite loop */
  while (1)
    /* Update PA0 drive strength and slew rate */
    GPIO_DriveStrengthSet(SQUARE_WAVE_PORT, driveStrength);
    GPIO_SlewrateSet(SQUARE_WAVE_PORT, slewRate, slewRate);
    /* Enter EM1 until a push-button interrupt triggers a wake-up */
    EMU_EnterEM1();
