Hi, sometime I need to test the continuity in the circuit board. I mean during rework. Mostly there are one or more MCU on the control board. My Fluke 87V has a 9v battery. Is there any tester who work with low voltage? Maybe under 0.4v so I can exclude the diode during continuity test. Which voltage is safe tu use on an MCU during a continuity test?
Thank you.
Thank you.
