Both are switches as mentioned. You choose a switch based on application at design time. In some designs a N/O or N/C push button is the better choice. The designed has an endless array of switches to choose from. You make the choice based on application. I want to start a 40 HP motor drive. I use a N/O push button configured in a latching circuit. I use a large red E Stop N/C push button to open my latched contactor and stop the motor. I want to turn On / Off a simple lamp so I use a simple toggle switch.Hello, I would like to know what are the situations, and why push buttons are used instead of switches in industrial electronics?
Yes, I mean momentary Contact vs two position.A push button is a switch. Do you mean momentary contact vs two position?
Lock OFF.!Can someone tell me why the Emergency Stop button in post #6 has a key?
I can think of no reason where you would want to lock out an emergency stop.
That would be it. I actually have one of those around here somewhere. The infamous somewhere.Lock OFF.!
Prevent some re-start when maintenance being performed..
Or jig changing etc.
One other 'sneaky' type used is palm buttons, these are buttons where an operator has to place each of his hands over each button in order for the machine to start/continue the process.Hello, I would like to know what are the situations, and why push buttons are used instead of switches in industrial electronics?
by Duane Benson
by Aaron Carman
by Aaron Carman
by Jake Hertz
