PIC16F18044
I am new to pic MCU. Can some one tell me whats wrong with the code . LCD jhd162a is not displaying the desired result, i am attaching the lcd display pic , please help me resolve the problem.
C-like:
// PIC16F18044 Configuration Bit Settings
// 'C' source line config statements
// CONFIG1
#pragma config FEXTOSC = OFF // External Oscillator Selection bits (Oscillator not enabled)
#pragma config RSTOSC = HFINTOSC_1MHz// Reset Oscillator Selection bits (HFINTOSC (1MHz))
#pragma config CLKOUTEN = OFF // Clock Out Enable bit (CLKOUT function is disabled; i/o or oscillator function on OSC2)
#pragma config VDDAR = HI // VDD Range Analog Calibration Selection bit (Internal analog systems are calibrated for operation between VDD = 2.3 - 5.5V)
// CONFIG2
#pragma config MCLRE = INTMCLR // Master Clear Enable bit (If LVP = 0, MCLR is port-defined function; If LVP = 1, RA3 pin function is MCLR)
#pragma config PWRTS = PWRT_OFF // Power-up Timer Selection bits (PWRT is disabled)
#pragma config WDTE = OFF // WDT Operating Mode bits (WDT disabled; SEN is ignored)
#pragma config BOREN = ON // Brown-out Reset Enable bits (Brown-out Reset enabled, SBOREN bit is ignored)
#pragma config DACAUTOEN = OFF // DAC Buffer Automatic Range Select Enable bit (DAC Buffer reference range is determined by the REFRNG bit)
#pragma config BORV = LO // Brown-out Reset Voltage Selection bit (Brown-out Reset Voltage (VBOR) set to 1.9V)
#pragma config ZCD = OFF // ZCD Disable bit (ZCD module is disabled; ZCD can be enabled by setting the ZCDSEN bit of ZCDCON)
#pragma config PPS1WAY = ON // PPSLOCKED One-Way Set Enable bit (The PPSLOCKED bit can be cleared and set only once after an unlocking sequence is executed; once PPSLOCKED is set, all future changes to PPS registers are prevented)
#pragma config STVREN = ON // Stack Overflow/Underflow Reset Enable bit (Stack Overflow or Underflow will cause a reset)
// CONFIG3
// CONFIG4
#pragma config BBSIZE = BB512 // Boot Block Size Selection bits (512 words boot block size)
#pragma config BBEN = OFF // Boot Block Enable bit (Boot Block disabled)
#pragma config SAFEN = OFF // Storage Area Flash (SAF) Enable bit (SAF disabled)
#pragma config WRTAPP = OFF // Application Block Write Protection bit (Application Block is NOT write protected)
#pragma config WRTB = OFF // Boot Block Write Protection bit (Boot Block is NOT write protected)
#pragma config WRTC = OFF // Configuration Register Write Protection bit (Configuration Register is NOT write protected)
#pragma config WRTD = OFF // Data EEPROM Write-Protection bit (Data EEPROM is NOT write-protected)
#pragma config WRTSAF = OFF // Storage Area Flash (SAF) Write Protection bit (SAF is NOT write protected)
#pragma config LVP = OFF // Low Voltage Programming Enable bit (High Voltage on MCLR/Vpp must be used for programming)
// CONFIG5
#pragma config CP = OFF // Program Flash Memory Code Protection bit (Program Flash Memory code protection is disabled)
#pragma config CPD = OFF // Data EEPROM Code Protection bit (EEPROM code protection is disabled)
// #pragma config statements should precede project file includes.
// Use project enums instead of #define for ON and OFF.
#include <xc.h>
#include <pic16f18044.h>
#include <stdint.h>
// Define MCU frequency
#define _XTAL_FREQ 1000000
// Define LCD pin connections
#define LCD_RS PORTBbits.RB4
#define LCD_RW PORTBbits.RB5
#define LCD_EN PORTBbits.RB6
#define LCD_DATA PORTC
// Define named constants
#define LCD_FUNCTION_SET_8BIT 0x38
#define LCD_DISPLAY_CONTROL_ON 0x0C
#define LCD_CLEAR_DISPLAY 0x01
#define LCD_ENTRY_MODE_INCREMENT_CURSOR 0x06
#define MAX_DIGITS 10
// Function to send command to LCD
void lcd_command(uint8_t command) {
LCD_RS = 0;
LCD_RW = 0;
LCD_DATA = command;
LCD_EN = 1;
__delay_us(1);
LCD_EN = 0;
__delay_us(100);
// Function to send data to LCD
void lcd_data(uint8_t data) {
LCD_RS = 1;
LCD_RW = 0;
LCD_DATA = data;
LCD_EN = 1;
__delay_us(1);
LCD_EN = 0;
__delay_us(100);
// Function to initialize LCD
void lcd_init() {
// Wait for LCD to power up
__delay_ms(20);
// Function set: 8-bit mode, 2 lines, 5x8 font
lcd_command(LCD_FUNCTION_SET_8BIT);
// Display control: display on, cursor off, blink off
lcd_command(LCD_DISPLAY_CONTROL_ON);
// Clear display
lcd_command(LCD_CLEAR_DISPLAY);
// Entry mode: increment cursor, no shift
lcd_command(LCD_ENTRY_MODE_INCREMENT_CURSOR);
// Function to display an integer on LCD
void lcd_display_integer(uint32_t num) {
// Maximum 10 digits
char buf[MAX_DIGITS + 1];
// Convert integer to string manually
int i = MAX_DIGITS - 1;
while (num > 0 && i >= 0) {
buf[i--] = (num % 10) + '0';
num /= 10;
while (i >= 0) {
buf[i--] = '0';
// Display string on LCD
for (int i = 0; i < MAX_DIGITS; i++) {
lcd_data(buf);
void main() {
// Initialize LCD
lcd_init();
while (1) {
// Display integer on LCD
lcd_display_integer(123456789);
// Wait for a short period of time
__delay_ms(1000);
// Clear the display
lcd_command(0x01);
// Display integer on LCD in reverse order
lcd_display_integer(987654321);
__delay_ms(1000);
lcd_command(0x01);
