Hey fellaz,
I've got a very large 4s 12v LifePo4 battery that I need to charge using my car's alternator while driving.
Obviously I can't just connect it directly to the cars 12v System since this battery will pull hundreds of amps from the alternator if the battery is fairly depleted.
So normally the obvious solution would be to use a CC/CV BOOST or Buck Converter, but the issue I think I'm going to run into going that route is normally there needs to be at least a couple of volts difference between the input and output in order for the boost or buck converter to work properly.
The voltage of my alternator is somewhat low and usually outputs around 13.5v. The LifePo4 battery voltage is between 10v completely discharged(not very often) and 14.4 fully charged.
The other option would be to use a MPPT or Pwm solar charge controller but I'm not sure either of those are able to charge a battery with the input voltage being so close the batteries voltage...
The only other thing I can think of is to use a boost converter to boost the cars voltage and then use a cc/cv buck converter to charge the battery.... I know I'm going to lose a ton of the efficiency that way but that's not really an issue in this situation
I'm curious what your guys thoughts are about this. I know they make a car DC DC battery Chargers but there fairly expensive...
