Thank you.A DPDT (Double Pole, Double Throw) switch should take care of the problem.
So you wanted it to be momentary?Purchased it on Amazon.
Oh yes it should be a maintained versionSo you wanted it to be momentary?
What are you switching? There is VERY big difference between switching a microphone signal and switching the electric power to a furnace.Looking for switch/splitter so that when A to A’ is connected, B to B’ is disconnected and vice versa.
Seems like a lot of stuff to switch an intercom from listen to talk.A contactor set-up may be more suitable, together with stop/start P.B.s depending on the application,
I don't see any post by the OP referring to an intercom???Seems like a lot of stuff to switch an intercom from listen to talk.
ak
I know. I'm just hammering home the fact that whatever is being switched is a secret. Wild speculation ensues.I don't see any post by the OP referring to an intercom???
