I am building a cubesat that will be launched aboard a rocket, inside a locker in the pressurized crew capsule. One of the onboard experiments calls for radiation level sensing. I see that the Pocket Geiger Type 5 (SEN-14209) needs to remain still, otherwise it will give false readings. The cubesat will be experiencing high levels of vibration, acceleration, deceleration, and freefall throughout the flight. Is there any way to differentiate the noise from genuine radiation readings?
Once the rocket engines shutdown, and the capsule disconnects, there will be moments of weightlessness and free-fall. Do you think that the sensor will be able to pick up usable readings during this period? It will be approximately 300km in altitude at its apogee, and outside the atmosphere, so hopefully vibrations will be minimal for a little while.
We also do high altitude glider experiments and regular high altitude balloon flights carrying cubesats up to 33km in which the sensors will undergo vibration, acceleration, deceleration, and free-fall. We use Arduino for all of these experiments, as they are cheap and accessible for teachers and their students. The Pocket Geiger Type 5 would be perfect for our experiments, as it is small and light-weight. I just need to figure out a way to overcome the vibration issue.
Any advice would be greatly appreciated!
