I read the information from another thread here about how to wire a 12v motion sensor but the replies confuse me a bit, can someone else please clarify this for me? This is what I'm understanding from the replies here and from amazon reviews: from the sensor we get 3 wires, connect the blue and brown wires directly to the battery to supply power to the sensor, So my confusion is the load wire. It can either be connected to the positive side of the lights or the negative side. I can tell by using common sense they are all saying connect the Load from the sensor to the positive side of the lights but user RB said and I qoute " when the unit detects movement the LOAD terminal is switched to ground" , shouldn't he have said the Load terminal is switched to power (positive)? preface I'm not an engineer, I'm just learning how to setup landscaping lights for my mom's house. the qouted thread is below:
FURTHER questions I have: I plan on separating my lights into 3 groups, front of house, left and right side of house. Each side will have it's own combination of lights to light up various things. so basically let's say on the right side of the house (if you were to look directly at the house from the street) I could have a six light string of 6 watt LED floodlights. I place a long 2 conductor wire down the right side of the house and each light's positve wire is connected to this wire on the positive side, all light's negative wires get connected to the negative wire on this 2 conductor. So the motion sensor is just a switch to connect this light string to the positive end of the battery, and the negative end of the light string connects directly to the battery negative, I think?
The actual question is that I need 2 motion sensors: one on each end of the right side of the house, that way the entire string will light up if either sensor triggers. I think I get it, the motion sensor is nothing more than a relay that requires it's own connection to the battery to provide the power to activate the relay so the Load wire is the only thing I need to worry about. I just need to wire a sensor to each end of the light string's positive wire side and add an extra 2 conductor wire to provide power to that sensor from the battery right?
Some one also said how to add a switch to bypass the sensor to light up the whole string, I never could figure that out so this forum is really helpful. just here to make sure I understand things right, hope I didn't sound too confusing.
also one last question if I were to accidentally reverse the polarity does it fry the sensor? the links to my parts
6 watts lights plus the 20 and 30 watt ones, I will repaint and silicone the whole light to waterproof it and even spray 2k urethan paint on the circuit board inside just in case
https://smile.amazon.com/dp/B08QF29G3L?ref=ppx_yo2ov_dt_b_product_details&th=1
sensors:
https://smile.amazon.com/dp/B09LQV5RWH?ref=ppx_yo2ov_dt_b_product_details&th=1
I just thought of this but I will use this wireless remote to use as a sensor bypass:
https://smile.amazon.com/dp/B09B6MRMNL?ref=ppx_yo2ov_dt_b_product_details&th=1
I have heard the best thing to do is use a relay and have all sensors activate this to activate the light strings, I will use this only if I have to: https://smile.amazon.com/dp/B079BGGVYX?ref=ppx_yo2ov_dt_b_product_details&th=1
He also said no more than 40 watts, but my lights are 6 watt, 20 watt, and 30 watt LED floodlights. LED lights are a resistive load are they not? So it should be OK for me to use the 80 watt max load listed here? (as an example, I will go back to the product page to see the real specs of my lights).Hi.
The three wires are connected like this;
+ (+12v)
- (12v ground)
load (connect the light between here and +12v)
So in use, when the unit detects movement the LOAD terminal is switched to ground. So the load (the light bulb) goes between +12v and the LOAD terminal.
Your 12v light should be no more than 40W for best reliability.
sensors:
