Hello Everyone, I am new here and don`t know if i am posting this in the correct place. Can anyone tell me what is this part? This was connected to the motor of a handheld vacuum cleaner. This was connected on both wires, positive and negative in between the motor and JST plug that connects the motor to the PCB. Attached are pics of the motor with the wires. I tested it for continuity and it showed continuity.
I cut off this bit along with the transistors at the end of it and soldered the positive and negative wires to the the motor and it bypassed the on off switch. The motor started when i connected the battery pack to the pcb.
cheers
cheers
