Is this a homework question? If so, we need to see your best effort at a response before we can help.what's the difference between LCR Meter vs LCR or Bridge
what is the advantage?
what are the disadvantages?
What is better?
I must say right away that the LCR meter must operate at different frequencies.what's the difference between LCR Meter vs LCR or Bridge
Exactly what are your needs ?what's the difference between LCR Meter vs LCR or Bridge
What is better?
What are you measuring, R, C, or L?i need a very very Precise measurements
Then you'll also need a fixture for SMD work and maybe a 4 wire Kelvin clip set also.i need a very very Precise measurements
How precise? Numbers?i need a very very Precise measurements
They can all be the same and have just one function, to make L, C and R measurements.it is not Homework
i just need to know : what's the difference between LCR Meter vs LCR or Bridge ?
In two or three sentences
In three sentences:i just need to know : what's the difference between LCR Meter vs LCR or Bridge ?
I already answered your question in post #2.it is not Homework
by Jerry Twomey
by Duane Benson
by Aaron Carman
by Jake Hertz
