Help Identifying Part - Burned Resistor
Brewtrooper
Joined May 28, 2015
5
I have a burned resistor and I'm hoping that someone with more experience than me can identify it. I'm trying to fix a strobe light for my daughter. I've attached pictures. I'm guessing it is a 10 or 100 ohm 10W resistor. Many thanks to anyone willing to lend a hand here. :)
Brewtrooper.
dl324
Joined Mar 30, 2015
16,909
Can't read the color codes. Size looks like 2W to me; 3W if it's a "miniature" form factor.
From Yaego:
What makes you think it's bad?
WBahn
Joined Mar 31, 2012
30,045
My guess is that it's white-white-silver-silver. But white-white (99) isn't a standard value, so that's probably wrong.
It doesn't look burned, but it does look like it gets hot enough to discolor the PCB underneath it.
Brewtrooper
Joined May 28, 2015
5
How do you know that the resistor is burnt?
Thanks for the response. I know it is "burnt" because it is swelled and cracked, and is open i.e. infinite ohms. There's also a pretty good char mark underneath where is it mounted on both sides of the circuit board. "Burnt" is my technical term. :)
Brewtrooper
Joined May 28, 2015
5
Thank you very much for the reply. It is open, so I know it's bad. There is also a crack in it. I've assumed that it overheated and opened. My daughter left it on for a few days in our basement, so I'm assuming it just overheated over a longer than designed duty cycle.
Brewtrooper
Joined May 28, 2015
5
From Yaego:
Thank you very much for the reply and information. Much appreciated. I tested it in circuit and it is open. I'm thinking of just putting in a large resistor and seeing if it brings it back to life enough to see it working, and keep trying smaller values until it works.
If you other suggestions, I'm all ears/eyes.
Thanks again. I really appreciate your reply and trying to help!
dl324
Joined Mar 30, 2015
16,909
It's a small value resistor. Read the color bands for us. I read 'something - white - gold - silver'. With a gold (0.1) multiplier, it's not going to be very large.
The only color that could be in the first position is orange, but it doesn't look orange to me.
