Started on the road to FPGAs and looking at boolean algrebra. I was doing the full adder example and wanted to confirm my assumption. There answer was used the expression (A ^ B) and mine used (!A ^ !B).
Are these equivalent and therefore negation does not matter for XOR if the same?
Here is my full solution
Please be kind
Thanks,
Code:
module full_adder (
// Inputs
input [2:0] pmod,
// Output
output [1:0] led
wire A;
wire B;
wire C;
// Set A, B, and C to buttons and off
assign A = ~pmod[0];
assign B = ~pmod[1];
assign C = ~pmod[2];
// Taken from above working
// led[0] C (A̅ ⊕ B̅) + AB
// led[1] C ⊕ A ⊕ B
// Cout
assign led[0] = (C & (!A ^ !B) ) | (A & B);
// S
assign led[1] = C ^ A ^ B;
endmodule
Thanks,
