I designed a DC-DC power supply, it is a buck-boost topology, the design is based on DC-DC controller LM5118, the circuit is as below picture shows:
When I am debugging the circuits, I found the output voltage level is right as expected voltage 48V under different current load, but the inductor of L16 is very hot even with a current load 1A, is there anyone can give some clues what caused the inductor hot issue and how to fix this issue?
Thanks and with best regards
Calvin
Calvin
