I have a question.
Im using BQ24002PWP Charger IC you can see in the schematic which I add. But I want to change IC with BQ24008PWP Charger IC because of TMR_EN feature.(to out of order the timers.)
BQ24002PWP use 2 individual LED.
BQ24008PWP use 1 bi color LED.
In datasheet write "The output stage is totem pole for the bq24001 and bq24003 and open-drain for the bq24002."
and "The output stage is totem pole for the bq24007 and bq24008."
I dont know what the mean is totem pole. I looked a little but didnt understand too much.
So the question is can I change BQ24002PWP with BQ24008PWP without changing my circuit? If I can, can you describe or draw it how?
Schematic;
Also what i want with more visual;
I have a question.
Schematic;
