Hopefully I've chosen the correct sub-forum for this post...
I am t'shooting a dim vacuum fluorescent display (VFD) on an appliance control panel. See attached image—the two displays' intensities are obviously different. The top display shows normal brightness for both displays.
There is no 'display intensity' setting for either display. The intensity of the lower display is not intermittent; meaning, temperature/humidity differences, thumping the control panel, etc. do not effect the brightness—the display has settled at its current intensity.
The control panel cover conceals two distinct circuit boards that drive a respective appliance; no interconnect exists between them. Each circuit board appears to use two different display technologies. Notice red cathode lines visible in the lower display (which is why I presume this is a VFD), while none are visible in the top display (I'm not certain what manner of display unit is used here).
My initial presumption is that some upstream component has failed and is causing a voltage drop to the display unit proper—like perhaps the circuit board needs recapped..? I have no idea.
Given the electronics nature of this problem, I figure it prudent to present my quandary here. rather than post my issue in an appliance repair forum—which would likely suggest replacing the expensive control panel. I'd like to repair the circuit board rather than replace it since the thing functions normally and the display is still readable.
Suggestions, recommendations?
