4 Bit Bouncing Flip Flop Design
Taksiepacze
Joined Nov 22, 2022
Hi all, im currently designing a 4 bit synchronous bouncing counter. The counter has to perform this sequence when a 1 or high input is applied :
'15,8,9,10,11,12,13,12,11,10,9'​
Otherwise, when a 0,0 is applied the counter should hold the current value, when 0,1 the counter should reset back to 15 and when 1,1 the state is invalid.
I've created an appropriate state diagram and transition table with the Current State, my SR Inputs , Next state, 4JK's and my outputs. However where im struggling is when creating the Kmaps for my JK flip flops, each JK needs 8 Kmaps, 2 per SR input state and im wondering how i would combine these to find out my equation for my final JK Equation, can i simply add each function deduced from my Kmaps for each state?
If i need to elaborate more ill try my best.
Taksiepacze
Joined Nov 22, 2022
Hi there, nope im not the same user as in the link - probably someone in a similar course - the values are different from what i see but its a very similar question.
RBR1317
Joined Nov 13, 2010
714
If the counter is in state '12' then how will it decide whether the next state should be "13" or "11"? Are the SR inputs used for the sequential logic or just used to force the initial state?
WBahn
Joined Mar 31, 2012
30,075
Your spec doesn't quite make sense.
You say when a 1 is applied it does something, which indicates that there is just a single input. But then you talk about what happens when a 0,0, a 0,1, and a 1,1 is applied, which implies two inputs. What does it mean for the state to be invalid when a 1,1 is applied? And how is applying 1,1 not applying a 1, which would indicate that it should step through the sequence.
Are you using SR flip flops, or JK flip flops, or a mix?
In either case, you will have two equations for each flip flop. Each input has its own equation.
