I was considering using a Rele but they don't work very well with high current (the ones that work are expensive) since its a high current I need the circuit to hold and at the same time not have much resistance when the current is passing through it. Is there any circuit I could use? I think that maybe there are some circuits with transistors but I'm not an expert on it so I'm seeking some advice from you guys!
